Wheel Re-spray
Well I said I'd try and get the wheels sorted (hopefully before Castle Combe) so here goes.
Needed to remove all the remaining evidence of the Existing FORD badges from the center caps first.
Easyer said than done
See what I mean (above)
Then I tried to use some Kniffing Stopper putty to cover the badges and make the area look flush.....I say tried as I made a right hash of it all
A bit of a bodge job...but not to worry, sanded them down and sprayed them up with some primer first then a couple of coats of Graphite Grey Metalic.....It doesn't mater that it sn't spectacular as I've got some of Uncle Alans stickers to go on the centers so hopefully you wont notice.....even though I've just told everyone
(which I will prevent from removal with some clear laquer)
Now at the same time I started on the rims too, were the old bang on weights had been when I 1st sprayed the wheels.
I also had a go at the face were i'd scratched it
My earlyer repair work looks a little shoddy now a couple of years down the line (I hit a kerb and gouged a big chunk out of the wheel)
I did start to mask the wheels up to spray the rims etc. however its started raining BIG style so will have to try that another day (the wheels need a bloody good clean)
So thats it for the time being.
I wish I had a Garage this would be so much easier.....
