On the plus side I was getting 36 to the gallon over to Johns thats a damn site better than the 21 I'm showing at the moment.
That was the plan Si but......
I wanted the C2 lights on the fourby but after removing the lights and grille at HQ and seeing the pain in the ar*e of a job needed (removing some metal to accommodate the C2 lights) the plan changed to fitting C1 lights to the C2 and selling the C2 lights seperately.
Then....
Upon attempting to fit C1 lights to the C2 - I knew the indicator bulb holders were different between C1 and C2 so I spliced in a C1 bulb holder.....only to find that the main connector for the headlights is also different. Too much of a pain to start messing about with the headlight loom so that was that too!
Still, it will add a little bit to the value of the car still having a full C2 exterior rather than the bit of a mongrel it would have ended up as
Edit: I forgot about having to take a hacksaw to the grille too as a C2 grille will not fit with C1 headlights without trimming![]()
Cheap, ATM, C2 grille here:
http://cgi.ebay.co.uk/Genuine-Ford-...arts_Vehicles_CarParts_SM&hash=item1c1c94fc69
Zetec is the way forward - I'm a man converted. Particularly with a custom B&M exhaust system - it sounds fantastic!![]()
Zetec is the way forward - I'm a man perverted. Particularly with a custom B&M exhaust system - it sounds fantastic!![]()
Zetec is the slow way forward - I'm a man converted. Particularly with a custom B&M exhaust system - it sounds fantastic!![]()
Nice twisty road in the wet and I'll blow both of you into the middle of next week![]()
Your thinking body roll the stiffer the car the worse it is when it lets go they are brilliant to a limit mine will grip and steer past that limit. Ask Kully
Don't take that as a slight Richard yours handles like a dream!.
