If you have a faulty coil-pack, theoretically at least it's failed for a reason (they shouldn't spontaneously fail) so now is the time to systematically examine the rest of the ignition system carefully. Multi-plugs, leads, spark-plugs, even engine earth straps etc. These bipolar DIS systems are very 'fussy', and what might seem inconsequential to an older style ignition system may really upset a system like this.
Regards,
Andy
Sorry, I misread it earlier, it is the three bolt pack that you need.
Is it definitely ignition related? From 9.5 years of ownership, the one recurring issue was that very few people know anything about these cars and bull**** their way through repairing them, at the owners expense.
Oh yes, to set the record straight......
They have been known to crack and earth to the body.
Yes its from a 2001 c2 mate 3 bolt. And as for your mechanic £13 quid a plug he's taken the p***No idea mate. They cost them £13 each so dunno if that makes them any good........
For the cougar 2 shaggy? That seems to be my problem![]()
Listen I'm doing a trunk every night this week to Warrington so I can take the coil pack with me if you can get over for it.
Hi Adam, I have a C2 & had the same problem as you have, after I went through a large puddle I did not see, the engine light was flashing, it turned out to be plug number one needed changing & the leads were cleaned. fault codes cleared & now runs sweet as a nut,
A spark plug socket, a 10", 3/8" extension and about 6 minutes is all it took me to change the back 3 plugs in my car. The one closest the IAC valve seems to be the tightest to get at but not a problem at all.
I'm using Denso plugs at about £6 each with no problems at all.
Anyone got a baseball bat for a rather RUBBISH garage![]()
I would have asked to see all of the old plugs
They really that bad?What he is getting at is, Ngk are ***** in a cougar and can often lead to misfires.
Motor craft have a much better record.
They really that bad? I'm using some NGK Laser Iridium plugs (best ones I could get) in the V6 now, they weren't cheap (£58 for the set) and they seem to be running spot on. Is this something I need to watch out for with 'em?
