Fitted the eBay bargain C2 leather front seats I collected from Portchester last Sunday.
As I'd hoped the fully electric and heated driver’s seat was a straight swap for my passenger seat and by swapping the seat base and loom from my driver's seat to the leather passenger seat I have retained the motorised 'up and down' and heating functions of my original seat.
To say that bolt is in an awkward place is an understatement but you could drill the head off the bolt with a long bit and the airbag will be loose
Or for a real fun time take an angle grinder to the airbag to get at the nut behind it if only there was a way to safely set off the airbag first that could work
Those seats look great, Andy, much like the car as a whole. One bonus in running a left hooker is that what is now your driver's seat has much less wear on the bolsters.
Matt, they are Torx bolts and are buried in the back of the airbag and are only accessible from behind the steering wheel. Access is somewhat limited unless you remove the steering column as Al suggested to Chris when he touched on this problem previously. Failing that I have a right-angled drill adaptor Chris is welcome to borrow, it could find it's way to 'Fest with you if he would like to give it a go.
Many thanks for the positive comments regarding the seats; I'm really happy with the outcome and, as Rich has alluded to, my now driver's seat is in fantastic condition having previously had less wear as a passenger seat.
Having been involved with several seat swaps I am now firmly in the 'swap-the-looms' camp rather than the 'swap-the-pins' camp, much more straightforward.
There's always a first time for everything.
Even with the drill adaptor it would probably be easier as a two man job; one to hold the drill and one to sit in the seat to ease the adaptor and drill bit towards them in order to exert enough pressure on the bolt head.
Socially distanced of course
Its sounds like something that would be almost impossible to do without graunching up the back of the steering wheel.
If it was a must do I think I’d opt for Al suggestion of removing the column.
I’m C1 car and C1 wheel, I do prefer the look of the C2 wheel, but for me I’m not sure it would suit the rest of the C1 interior. Just my opinion of course, others are equally valid.
Quicksilver, to make your interior absolutely spot on 100% perfect you just need......
