What Jamie Did... (Ha Ha 56k, you don't have broadband)
I finally found the last of my Aberdeen Photos
A replacement heater dryer motor from a '97 1.8 Mondeo.
Jamie got stuck.
I show him how it's done.
My heater dryer motor installed.
I need to replace this part, but I don't know what it's called so can't order a replacement. It's some kind of air flow valve. Can someone please help?
Jamie tried to clean it.
This is where it goes.
lottysvdub said:
did you get the thingy you were looking for ? its called an idle speed control valve :D :D :D :D :D
I got it, but my Cougar is still stalling at idle revs :x. Computer diagnistic may be necessary.
have you checked for air leaks around the throttle body and inlet manifolds or any of the surrounding pipe work ?? could be worth a check buddy can be done very easily with a tin of carb or brake cleaner , have the car idling and carefully spray the carb cleaner around the throttle body , inlet manifold and all the vaccume pipes around the inlet manifold and the throttle body , be very careful not to spray near exhaust pipes or any other sorces of ignition , if the revs rise you have a leak at the offending item you have sprayed . hope this is some help :D :D :D
Thanks, I'll look into it.
Procomm said:
hello just had a look at the pics looks cool 8) just a question my gear linkage looks like yours except i am missing one of the orange thingys, are they important? doesn't seem to make a difference :?
I'm no expert, but if the gearbox feels right to you than you will probably be alright. If worried you could probably get a replacement on the cheap from a scrappy. The linkage will be shared with a simular vintage Mondeo.
