Ok remove the trims on either side of dash which sit between the dash and door by the rubber seal you will see four silver/gold torx bolts and two black torx bolts per side undo the black ones, then down the side of the glove box there are two torx bolts there and two down the side of the panel that comes off from under the steering wheel, I will try to take some pictures tonight of where they are for you to help identify them.
