i know have blue footwell lights - managed to relocate the ones i was using to light up my CD player now i fitted a new ones. its the little things
Having today looked in T241/Zetec, the sunroof feed and warning lamps console wires are absent. Does this point to neither being offered as an option on the Zetec, hence not being included as part of the loom?What I like about my method;
It utilises an existing wire that runs the "difficult" part of the path;
Whether a sunroof is or isn't fitted...
I have a dashcam since the car before Cougar Zetec.
In Cougar Zetec I had hidden the power wire, behind the passenger A-pillar trim, plugged into a twin accessory socket (also with hidden feed for sat-nav) behind the lighter socket, but which was still plugged into the lighter socket.
As such this was still unsatisfactory with the lighter socket permanently powered meaning the camera had to be unplugged when stationary.
Considering a neater solution for MV51, and after discovering in Zetec a cavity above the courtesy lamp I decided to fit a single accessory socket there, knowing it could get permanent 12v from the map lamp feed. This would also free up the lighter socket.
Earlier I asked if there was a switched feed in the vicinity (MV51 has the extra warning lights console there) and @FlamencoAssassin helpfully informed me that the sunroof loom socket is there; this shares fuse with the power windows which only operate with the key turned, the ideal switching for the camera.
So soldered the accessory socket (removed from a coiled extension lead) to the cut wires from the sunroof feed, pushed the camera's mini-USB power cable out between the headlining and windscreen, wound up the excess cable and stowed above the courtesy lamp.
Photos; 1 & 2: the dashcam fed direct from lighter socket, with cable draped over rearview mirror
3: with the lamp housing removed, warning lamp console hanging before unplugging, sunroof socket (green and black wires) just visible pegged to inner roof skin at right
4: accessory socket soldered on instead and
5: reassembled showing camera powered via key switched feed.
It seems possibly the case that the cable to power the sunroof is present on all V6s but not on zetecs; the one I did this to is a V6 X-pack without sunroof....No sunroof but I'm sure I'll find a way of doing it.
Thanks, but tyre shop already obtained and fitted new.I have a 215 50 16 tyre here if you need it?
Devon MFSM!![]()
Could be Matt, if people are willing to come this far? That's the problem with being this far down in the ol' west country. I wouldn't mind bringing my coug up country, but always worried about getting it to bits and finding more than I thought wrong and unable to then get her home again.
both melina and ejay have had oil/filter changes today....even used motorcraft filters...thanks ebay.
id come down there to work on such a lovely coug..but i know what u mean about getting her stranded....im sure she'd be safe at a club members place but hey i even get upset when i leave melina at the mot garage.
i think chris plans to do a subby on tiger at some point...maby double up if chris is happy with it...we certainly wont leave u stranded..
the trick is to save up as many bits u may need like droplinks or rubbers and we normally have some spare bolts ready..
Better off using the chunky ones from an exhaust centre Tim, poly ones are poo
tonys right about exhaust polys, they really dont last for some reason...i think its the heat that does it...had them on the scorpio and they all cracked around the mounting holes.
best stick to rubber me thinks.
Not had much time for Cougaring lately, between work, sorting out the Puma, bouts of raging toothache and visits to the dentist (which I hate).
However, inspired others around here, I got me a spare set of rear lights and some tinting spray, secured the use of one of the spray booths at work and had a go at making some darker taillights.
Unfortunately, I've made a mess of it. I'm trying to rescue it but I suspect I'll need to start again. Ho-hum, there's always next weekend I guess. More tinting spray (and tint remover) ordered....
