https://www.ecstuning.com/b-schwabe...3pUVcZNkjb4eYPueygyk6cQiME2Txl9BoCi7AQAvD_BwEI didn't know that. Wish I had known that.
Looks like these.
You know now.[emoji4]
You guys do know they make a tool for spreading that clamp on the knuckle apart so they come off easier right?
Ye, it's called a cold chisel, or a big screwdriver [emoji106]
No an actual legit tool whos purpose is strictly to spread the knuckle for strut removal lol.
A pry bar hammered into the slot also works
Or..... remove lower arms. Leave hang by the strut mount bolts and hit the top of the knuckle with a hammer Thor would be proud of.[emoji16]Insert chizel, hit hub with hammer, swear , repeat
... with a hammer Thor would be proud of.
Someone goes under with a knackered chisel to apply lateral pressure into the joint. Someone else with a bad temper hammers away at the knuckle with a 5lb lump-hammer.
This will escalate from "tapping" to "raining blows upon it like the fist of an angry god".
Whatever gets it done. And yes, I have been the (5'9" 140lb) maniac with the hammer.
From what I've read I would have figured you for the chisel guySomeone goes under with a knackered chisel to apply lateral pressure into the joint. Someone else with a bad temper hammers away at the knuckle with a 5lb lump-hammer.
From what I've read I would have figured you for the chisel guy 藍
Being under the car, Id be more worried about my head lolYou'd think so, but I'm not dumb enough to let any of these people use a lump hammer anywhere near my hands.
Is that a Euphemism ?
Sorry Mako, no offence to your good self intended !
Great quote and great film [emoji16]Heh. [Cpl Hicks] None taken. [/Cpl Hicks]
Modern cars...(sigh)...the attached image shows how much I had to disassemble to get to the clocks - four more screws to go and they're out, just so I can access the bulb I need to change...
The upside?
I now know more about how the interior goes together... :- )
I think ive got it down too 3 minutes now to get the clocks outYour first time? It's something of a rite of passage for all Cougarites, good on you for breaking your duck!
